08-12-2018, 12:55 PM
#35 (permalink)
I've experienced a vacuum leak on a MAF hose before, and it was similar, but not as bad as these symptoms.
I'm up to 8 cold starts with no probs since putting the Metro's coil back in.
However the car did throw a p0400 code on a 200 km trip this weekend. Intermittent EGR valve problem (I've seen it once before). I wonder how a stuck-open EGR valve would make it run.
I need to take it off & clean the valve &passages.
