Old 08-19-2018, 11:01 PM   #51 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Originally Posted by JohnAh View Post
but what really changed the game was to introduce "Burn & glide" driving in continous cycles of acceleration with almost full throttle, followed by coasting. When I started doing this the fuel consumtion decreased way more than by anything else, and I could not even see any difference from changing wheels or tire pressure.
The final very rewarding step was to introduce engine shut-down while coasting. This is just as extreme as it is rewarding! Fuel consumption made a huge dive again. An average burn & glide cycle has 15 20 seconds acceleration followed by 30-40 seconds of coasting with the engine shut off. Driving this crazy way is a lot of work, but you definitely get something back! :-)
I have installed two push-buttons on the gear stick and two relays. One button kills the engine by switches off the ignition. One of the relays "stick" in this position until the other button is pushed, together with the activation of the starter. I have a good engine that most times start in just one piston stroke so the load on the battery is not too heavy.
You, sir, are cheating.
Many people don't know that 96's original engine was a two-stroke. Those that do, not all know a two-stroke can experience oil starvation when you let off the gas while in gear. Mixed in the gas, high revs, low fuel-oil rate: much bad.
So what? So SAAB fits a freewheeling clutch. Let off the gas and the transmission goes along at its own speed, while the engine drops to idle so it won't self destruct. It's also a good idea not to hold constant revs on a two-stroke to avoid overheating.
So what, squared? When SAAB installed the Taunus V4, they retained the rest of the drivetrain, including the freewheel clutch.
So what, la troisieme? So when the burn is done, JohnAh merely need let up. Glide is done, push on the loud pedal.
In short, the 96 is literally designed for engine on P&G.
Adding a switch to kill the ignition has a tripping hazard however. When the engine dies, the freewheel means the transmission won't spin the engine for you when you turn the ignition back on.
(Edit)
Sweetie says, "You know that's how you would drive that car, so don't you tell him he's cheating."
She's right, of course. My bad.
The Following User Says Thank You to elhigh For This Useful Post:
MetroMPG (09-18-2018)
