Old 08-20-2018, 07:39 AM   #7 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by teoman View Post
The warm air vaporizes the fuel better. And with a warmer mix you get faster combustion.
Very true. And, as California98Civic says, you also have reduced pumping losses with a conventional automatic or manual. This will not be the case with a Subaru CVT, however, as reduced power will just cause it to rev higher. I could see this as being counterproductive.
Only way to know for sure is to test. I'd think running one in winter, at least, would be a good idea.
