Old 08-22-2018, 01:56 PM   #15 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
So, the Honda Insight was the prototype "L" series engine, which replaced the D-series in Honda's lineup. The Insight's engine is called an "ECA1", but it's really a 3 cylinder L engine, and is most similar to the engine in the HCH1 (L13) and Fit (L15). The most recent L15B engine is in the turbo Civic and delivers 200HP while capable of 60+ mpg in the hands of a capable driver - ask Balto about his time with one. The "L" engines have some major advantages over the D series. Read about it here:
The Truly Amazing Honda Fit/Jazz
Some highlights:
-10% weight over D series
Smaller dimensions
Smaller angle combustion chamber -> better combustion
Camshafts have roller bearings where the rocker arms contact -> lower friction
Molydebnum coated piston skirts -> lower friction
Crankshaft offset -> more torque, lower friction, longer engine life (this is huge!)
Time chain never needs replacement, lower friction
Plastic/resin intake, reduces weight
Higher compression ratio -> more efficient
Some L-series have dual spark plugs
Here Honda explained that the design objective of their new 'L-series' gasoline engines is that of achieving complete combustion, i.e. a combustion efficiency of 100%. This 100% efficiency is explained as 'complete burning of the air-fuel mixture without wasting a drop (of fuel) and converting all the energy of the combustion into kinetic energy'. A 100% efficient combustion is of course seldom if ever achieveable in real life. In order to improve combustion efficiency, Honda seeks to optimize the combustion process itself. The ideal combustion process is instanteneous combustion where the efficiency of the conversion of combustion energy to kinetic energy is complete. To approach instantaneous combustion Honda implements a dual approach : a 'remarkably intensive combustion' and 'combustion control adjusted to engine speed (rpm)'. In the L-series, these are delivered by its compact combustion chamber and the new i-DSI system.
Xist (08-22-2018)
