If you wanted the really tall final drive, you’d get a manual Gen7 civic and his CRX trans and have a transmission shop swap the guts into the Gen7 case(of course as part of a rebuild)...
I’m with you though, just grab an Insight or HCH1 with a decent battery... drive until the battery fails and then decide what to do... I’m sure the battery would store fine with a grid charger... you know, have somebody trustworthy plug the thing in once a month or so to keep it topped off...
You could delete the battery when it fails or you could replace it... personally I’m curious as to what could happen if you replaced them with a lithium pack of some sort(Headway cells perhaps?) and done an aftermarket AC motor controller, and used an Arduino to die it all in with the IMA system...
My current Ecotec project...
My last Ecotec project...
