Old 08-24-2018, 03:08 PM   #53 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Daox is still around.
Natalya's thread: https://ecomodder.com/forum/showthre...ght-34014.html
This one you linked is correct for both brake and clutch switch: https://www.insightcentral.net/forum...-walkthru.html
^ How it works is basically that there's a button on the brake and clutch which are activated when you press these. You can add a parallel button which lets you do it manually without having the hold the pedal in.
And, that's correct on how to take care of the battery - to my knowledge.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
mpg_numbers_guy (01-05-2019), Xist (08-24-2018)
