Old 08-27-2018, 12:32 PM   #14 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Does the ICE fire up when you need heat? Can you keep it in EV mode while mashing the accelerator?
EV mode will provide electric heat (it has a heat pump), but only down to a certain outside temperature. Owner's manual says -10 C / -14 F. Has a heated steering wheel, too.
As for mashing the gas, it will summon the ICE if you push it hard enough, or "suddenly" (says the manual). I haven't had it fire up on me yet, but I tend not to mash it. I've also been using it in ECO mode, which probably raises the ICE-assist threshold. EV mode keeps up fine with normal traffic flow around here.
I read that the previous gen. Prius plug-in took lots of flack in reviews because the ICE often fired up to aid acceleration. This version doesn't do that.
