Originally Posted by 19bonestock88
Do you want your trans to fail? Don’t block it’s cooler... the lawn edging air dam is a pretty effective mod, and side skirts are also fairly effective... look also into making wheel spats and removing a roof rack if you have one...
I have heard that unless you are towing or running AC through a very hot climate that it is safe...with monitoring. I was a little suspicious too.
thnx
