08-29-2018, 05:16 PM
#60 (permalink)
I have read that the ST Focus and Fiesta are quite tail-happy.
Only tail-happy FWD car I've had the white-knuckle pleasure of rescuing from fishtailing (it was actually downhill oversteer - similar cause as lift oversteer) was one with rear tires that were a lot more worn out than the fronts.
Which is why most tire shops will install new tires on the rear of a FWD vehicle if you're only getting a pair of new ones.
