Old 09-01-2018, 09:47 PM   #15 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
It shouldn't.
The trans is already turning, and the engine is already turning. In this case the trans is overspeeding the engine instead of the other way around as when shifting from N or P into D from a stop. The torque converter will absorb most of the shock, if indeed there is any, as the clutches engage. Revs match, all is well. Like others said, a blip to the throttle to get the revs closer will further reduce the shock.
I drove my Forester this way for 13 years, struggling to drag its mileage up from the mid-20s, and when I finally got rid of it it wasn't because of the transmission. Of all its systems, the transmission is the one component that performed flawlessly the entire time I had it, and by the time I sold off the car it had about 360,000 miles on it. I think he'll be okay doing this with his car.
The Following User Says Thank You to elhigh For This Useful Post:
royanddoreen (09-05-2018)
