Old 09-03-2018, 12:31 AM   #551 (permalink)
cRiPpLe_rOoStEr
Originally Posted by euromodder View Post
Only time it ever started on gasoline - aside from right after filling up- has been when it had stood at an airport car park for 3 weeks, quit instantly on CNG, restarted roughly on gasoline , yet it was 25°C !
I guess it follows an approach very similar to the "monovalentplus" employed by Opel on its CNG range. Well, even though in Brazil the up! is available only as a gasoline/ethanol flexfuel, since CNG can withstand to compression ratios higher than what would be safe to use with ethanol, it could somewhat explain the rough starts on gasoline...
