09-03-2018, 12:31 AM
#551 (permalink)
Originally Posted by euromodder
Only time it ever started on gasoline - aside from right after filling up- has been when it had stood at an airport car park for 3 weeks, quit instantly on CNG, restarted roughly on gasoline , yet it was 25°C !
I guess it follows an approach very similar to the "monovalentplus" employed by Opel on its CNG range. Well, even though in Brazil the up! is available only as a gasoline/ethanol flexfuel, since CNG can withstand to compression ratios higher than what would be safe to use with ethanol, it could somewhat explain the rough starts on gasoline...
09-06-2018, 01:21 AM
#552 (permalink)
 Karmann Ghia Aigle - Flat4ever.com
Originally Posted by Google translate
Nettle of the workshops Helvetic subsidiary bodybuilder Ghia located in Aigle in French-speaking Switzerland, the Karmann Ghia Eagle was produced only two copies and has never passed the stage of prototype ...
Karmann Ghia Eagle
This nice coupe is based on a Ladybug chassis, its braking system is of Porsche origin, the engine is the 1131cm3 "molded foot" decked a Judson compressor allowing it to deliver a power of 50 hp.
25hp to 50hp. Hella H-4 headlights. Cobra-style guppy mouth.
God's blessing on this wonderful world!
_________________
09-16-2018, 02:39 PM
#553 (permalink)
_________________
09-19-2018, 02:24 PM
#554 (permalink)
_________________
09-20-2018, 06:11 PM
#555 (permalink)
_________________
09-21-2018, 12:06 PM
#556 (permalink)
GasDwarf - '13 Volkswagen up! EcoFuel CNG
PON was the Dutch VW importer
10-03-2018, 04:52 PM
#557 (permalink)
Link title says it all.
http://justacarguy.blogspot.com/.../oh-good-grief.html
________
Anyone else who recognizes the name Randy Carlson?
The one-of-one is at 21:52, but there're old Packards and Fords leading up to it. Pictures on the wall of his other VWs at 6:56.
_________________
10-11-2018, 08:51 AM
#558 (permalink)
10-12-2018, 04:10 PM
#559 (permalink)
The 4 headlights give the variant 2 away. Same as the type 411
2000 F250 7.3 CC 20+ MPG @ 10000 #
2013 Golf tdi 47.5 mpg neutered, 1500 mi beer run
1988 Ranger EV Volt batts>> 18,000 MPG and climbing. Rag overhaul.
10-12-2018, 06:01 PM
#560 (permalink)
Basically a Type III body shell with different rear quarters and 411 headlights.
The Gol looks like the B2 Passat/Dasher with a shortened C-pillar. The body lines are very close. Probably a lot of the same stampings.
https://en.wikipedia.org/wiki/Volkswagen_Passat_(B2)
The Santana was also manufactured in China, Brazil, Mexico (as the Corsar, from 1984 and 1988) and Argentina (as the Carat between 1987 and 1991). In Brazil, the Santana station wagon was sold as the Quantum. The Passat saloon and estate were produced in South Africa for their local market until 1987. The production of Passat B2 in China ended in 2012.
A 39-year production history (1973-2012)? Why can't I find the preformed heater hoses?
_________________
