You can run the coolant fluid low, and use cardboard to keep the engine hotter than factory.
From the factory, all cars are calibrated to work best at 75F.
Anything higher, or lower, is somewhat calibrated by the fuel, but still runs slightly worse than at 75F.
It's always good to do minor mods to achieve that goal when possible.
