Old 09-06-2018, 11:00 AM   #161 (permalink)
90 day: 39.06 mpg (US)
Work Vehicle - '17 Toyota RAV4
90 day: 33.13 mpg (US)
That's about the only thing I miss in my Insight - the lack of lack of roof.
Old 09-06-2018, 12:49 PM   #162 (permalink)
90 day: 55.97 mpg (US)
90 day: 70.75 mpg (US)
90 day: 72.89 mpg (US)
boat tail!
Jumped the shark?
I got the idea from this pic I found:
But that's a much smaller boat.
Also, he should have put that on upside down.
Memories of...
ID:	24774   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
freebeard (09-06-2018), PaleMelanesian (09-06-2018)
Old 09-06-2018, 04:25 PM   #163 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Ha! That's a funny ad - there were no Swift convertbles!
Maybe not in Canuck territory, but we sure did get them over here in Europe
The Following User Says Thank You to euromodder For This Useful Post:
MetroMPG (09-06-2018)
Old 09-08-2018, 02:57 PM   #164 (permalink)
First fill since last October...
49.98 MPG US = 4.7 L/100 km
SO CLOSE. I HAZ SADS.
Needs more mods!
Also: it's surprisingly hard to get > 40 mpg in short local trips with a cold engine, even with lots of engine-off at appropriate times. This thing really sucks back the fuel when it's cold.
Old 09-09-2018, 04:51 AM   #165 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
trick it in to thinking the engine is warmer, sooner?
Old 09-09-2018, 05:02 AM   #166 (permalink)
You can run the coolant fluid low, and use cardboard to keep the engine hotter than factory.
From the factory, all cars are calibrated to work best at 75F.
Anything higher, or lower, is somewhat calibrated by the fuel, but still runs slightly worse than at 75F.
It's always good to do minor mods to achieve that goal when possible.
Old 09-09-2018, 08:47 AM   #167 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Why on earth would you run en engine low on coolant?
My current Ecotec project...
My last Ecotec project...
Old 09-09-2018, 11:05 AM   #168 (permalink)
Stubby79's Avatar
I assume 75f is ambient temp, not engine temp.
And yes, I wouldn't recommend running an engine low on coolant. If you want a similar effect, the higher the antifreeze content, the less heat it can absorb. So in theory, if you ran higher % of traditional antifreeze, the engine should warm up faster. You should still run some water in it, especially if it's going to be below freezing outside, so that it can absorb enough heat, and not freeze. Pure antifreeze freezes not much lower than pure water.
Old 09-09-2018, 12:59 PM   #169 (permalink)
To warm up the engine faster. Less coolant, quicker warmup.
You'll be ok with a low coolant level. Low coolant levels are well above the absolute minimum your engine needs to survive.
And yes 75F is ambient. Engines run over 200F.
Old 09-12-2018, 09:07 PM   #170 (permalink)
kayak trip
The air did not really like this setup.
With the boat properly strapped down, I struggled to get ~45 MPG (US) / 5.2 L/100 km on a 150 km round trip at speeds where I'd easily be getting 50+
Partly I think it was because the boat was positioned in line with the passenger side of the car (for outward visibility). Might have worked better dead center.
Ecky (09-13-2018)
