Old 09-13-2018, 11:45 AM   #38 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by oldtamiyaphile View Post
The new speakers were slightly too small, I hate the idea of MDF spacers (MDF really has no place in a car), nor did I want to wait for ABS spacers that still might not fit. I also hate cutting factory wiring on even the oldest jalopy.
So, I cut the speakers
The old speaker becomes the new speaker spacer. Don't have to drill out the rivets. The new speaker connects to the old speaker terminals, so all the wiring is intact. Only need a small hole in the speaker spacer to run your wires through, foam sealing tape and screw in the speaker.
Genius! I wish I had seen this before I replaced the speakers in my VW.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
