Old 09-20-2018, 10:39 PM   #27 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
ZUCCess!
My 1"x1" heater FINALLY showed up(partly my fault), and it looks like I could have gone bigger. The heater is only 10 watts, so I didn't expect much, but it does in fact work, and I did measure higher oil pan temps. I'll have to leave it plugged in for 2 hours and see what kind of oil temps it gets up to. I had it on for maybe half an hour, and saw oil pan temps climb about 6 degrees F. Temperature on the heater itself didn't go much over 200 degrees F.
Vacuum gauge is hooked up and sourcing vacuum from cylinders 1 and 4. Haven't gotten to ride it since that first test ride with 1 cylinder tapped cause I was fixing a coolant leak. The leak is fixed now, I just have to go get more coolant!
ID:	24849   Click image for larger version
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
