Old 09-23-2018, 07:44 PM   #16 (permalink)
coop8070
So the car broke down again today, but this time I have to tow it. I was pulling out into and intersection and the transmission popped out of gear and started grinding. I can't get the car to start in any gear. As so as I start to release the clutch there is a pop and the gear starts to grind. It does this in all gears including reverse. The shift linkage under the car looks fine. I hope I don't have to pull the transmission to solve this problem. Do you guys have any ideas? I can put it in gear no problem but it immediately pops out of gear when I start to release the clutch, even as I hold the shifter in place.
