Old 09-24-2018, 07:03 PM   #36 (permalink)
racprops
And there are a lot of other changes, heavy duty anti-sway bars front and rear, dual batteries under the frame behind the driver's door, with a relay to keep one fresh for a start in the morning, if you look close you will see A/C vents over the middle seats, the bed room, and the porty potty..and reading lights, and the rear A/C also reaches to the front seats, waste not.
Yes that is Jag Tach, and I hope to install its mate a Jag 140 MPH speedo soon, and yes a Mpgunio and a older mileage computer as well, not fully working yet due to the fuel return line..but I have a fix for that too.
A old Side Band CB with a power amp and triple power monitoring meters...
Sadly I have done a lot to her so giving up on her is not easy to do.
Rich
