Old 09-24-2018, 04:54 PM   #31 (permalink)
Still curious about the aerodynamics. One of these?
https://i.pinimg.com/736x/a6/03/94/a...64ba8bf80e.jpg
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Old 09-24-2018, 06:37 PM   #32 (permalink)
The Aerodynamics on my 93 Chevy van
Here you go:
ID:	24885   Click image for larger version
ID:	24886   Click image for larger version
The Following 2 Users Say Thank You to racprops For This Useful Post:
Ecky (09-24-2018), freebeard (09-24-2018)
Old 09-24-2018, 06:44 PM   #33 (permalink)
Van as I got her..
Note with out lowering is looks lowered. I feel usually compromises the suspension.
ID:	24888   Click image for larger version
The Following User Says Thank You to racprops For This Useful Post:
Ecky (09-24-2018)
Old 09-24-2018, 06:50 PM   #34 (permalink)
Name:	Center console Install 018.jpg
The inside is even more customized my yours truly:
Name:	Customizing the Van 001RAC.jpg
Name:	Customizing the Van 002RAC.jpg
Name:	Center console Install 013.jpg
Name:	Center console Install 014.jpg
Name:	Customizing the Van 007.jpg
Name:	Center console Install 011.jpg
Name:	Van progress 003.jpg
Name:	Van progress 004.jpg
Ecky (09-24-2018)
Old 09-24-2018, 06:56 PM   #35 (permalink)
More:
Sadly what seemed like a great idea, oil coolers to replace the wide turn singles lights in the grill, lased 15 years but took out my motor when a hose clamp failed:
Name:	Customizing the Van 003.jpg
Name:	Customizing the Van 004.jpg
Name:	Customizing the Van 002.jpg
Old 09-24-2018, 07:03 PM   #36 (permalink)
And there are a lot of other changes, heavy duty anti-sway bars front and rear, dual batteries under the frame behind the driver's door, with a relay to keep one fresh for a start in the morning, if you look close you will see A/C vents over the middle seats, the bed room, and the porty potty..and reading lights, and the rear A/C also reaches to the front seats, waste not.
Yes that is Jag Tach, and I hope to install its mate a Jag 140 MPH speedo soon, and yes a Mpgunio and a older mileage computer as well, not fully working yet due to the fuel return line..but I have a fix for that too.
A old Side Band CB with a power amp and triple power monitoring meters...
Sadly I have done a lot to her so giving up on her is not easy to do.
Rich
Old 09-24-2018, 07:40 PM   #37 (permalink)
Originally Posted by racprops View Post
I plan on keeping the automatic as 8l90 ...point is 8 gears...and with a super low 1st and 2nd gears can pull strong even with a 2.43 of lower rear end.
Is someone doing a stand alone controller for the 8L90? I know there's a couple for the 6 speeds, I haven't looked for the eight speed.
Old 09-24-2018, 08:01 PM   #38 (permalink)
I was going to use the factory unit...
Make it a piggy back set up.
Rich
Old 09-24-2018, 08:05 PM   #39 (permalink)
Thanks. You could:
  • replace the flexible front air dam with a diverter that extends forward to the stagnation point. Currently air that hits the front bumper winds up underneath. A diverter divides the air and lowers the stagnation point. Extreme examples on time attack cars.
  • Then the front wheel wells can have air curtains or spats (both?).
  • The sidewall curtains could be doubled up (see Aerocivic)
  • The rear fender skirts it needs could extend TurnpikeCruiser-style to an established rear separation point.
  • How do you feel about working with fiberglass? You could pie-cut the rear top. Cut it into strips and 'glass them back together for the proper curve.
Of course, a full boat tail fixes everything. How much do you want to drag around behind it (parking, visibility, etc.)?
________________
Old 09-24-2018, 09:07 PM   #40 (permalink)
" replace the flexible front air dam with a diverter that extends forward to the stagnation point. Currently air that hits the front bumper winds up underneath. A diverter divides the air and lowers the stagnation point. Extreme examples on time attack cars.
Of course, a full boat tail fixes everything. How much do you want to drag around behind it (parking, visibility, etc.)?"
I think I will need pictures of most of these ideas.
I am very close to the ground as she sits with the hard ground effect that came on her stock and feel I need the flex to allow some contact with irregular road and parking lots bumpers.
No boat tail...what about deflectors to bend air into the void in back??
Rich
