Old 09-25-2018, 01:03 PM   #105 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.53 mpg (US)
Originally Posted by hayden55 View Post
You know it honestly has gotten to such a great point to start upgrading hybrid batteries that I'm surprised people are still disabling the ima batteries on these cars.
Does anybody know what depth of discharge the OEM battery is designed to stay within on the bms? From the specs on Honda's website its 144V 6.5Ah battery. That's really only 80 18650 battery cells and you could do a couple packs of 40 cells to get whatever Ah pack you want. Similar to what Tesla does with 3350mAh 18650 cells. The cool part is that 80 cells weighs less than 8 pounds for the cells themselves and you could configure this pack to have so many cycles of capacity depeneding on dod that it would pretty last indefinitely (if configured to stay between 30-70% discharge the panasonic cells in the model 3 have a 40,000 cycle life). I don't know much about the oem pack. Does it have a battery fan, battery warmer?
A lot of reasons. The computers don’t like when you change battery chemistries. The BMS freaks out. And, normal off the shelf 18650’s don’t handle 100 amp charging rates very well. You end up needing a battery with 5x the capacity with high current rated cells so they don’t pop when you hit the brakes.
OEM pack doesn’t have a warmer, it just overcharges the batteries until they warm up, which would destroy lithium cells. There’s a fan, at least.
People are working on it, but it’s not remotely simple.
