Old 09-27-2018, 08:32 PM   #114 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Yeah but that one is much simpler. The IMA system doesn't assist or regen when the clutch is pressed, so you just add a clutch switch toggle. It's not physically turning anything off.
Wouldn't that work to prevent forced regen?
It would be ideal if it did, but that would probably be a tuning nightmare. There's just a lean and a normal map, and it switches between the two.
Ah, true. Besides, the Insight is very fuel efficient as it is already. Imagine if the same technology had been improved upon - lean burn, aerodynamic design, and all!
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
