Old 10-08-2018, 02:31 PM   #11 (permalink)
freebeard
Anyway thanks all for the ideas & suggestions but I'm trying to get an idea of my cost and effort for reward ratio. Is there a site to help me compare different modifications and what the energy savings would be? I'm sure I could spend $10G making it look like a rocket but I'm not going to do that. Im trying to find that sweet spot in the ratio (effort<=reward) and what to expect.
That would be Ecomodder. It's all anecdotal, because each owner and use case is different, but there are accepted principles based on both hearsay and evidence.
Question: If I have a square meter box, what is the aerodynamic reduction of force required to push that through air at 60mph if I instead it had a 45 degree leading edge? Is this an applicable question for the front box of the truck?
Every element has a Cd. Those are both summed and interactive.
If that greenshield thing works, maybe I could mimic the idea and use it to hide my spare up there. Reasonable?
It needs to be moved forward over the cab to maximize the length of roof behind it. Davits for storing and retrieving the spare? That's the style with [the decidedly unaerodynamic] Dekotora trucks. They started out as a place to store tire chains, etc. Colani's trucks use a tilted oblate spheroid:
https://en.wikipedia.org/wiki/Luigi_Colani
Here is a sketch I did for another thread, some of it might transfer to your case. Half-round front corners and a deflector ring at the rear.
Rear-view mirrors are also impotant.
I just discovered the archive view of the Aerodynamics sub-forum. Scan this list for item of interest:
https://ecomodder.com/forum/archive/f-6.html
Here's a list of relevant threads from here.
https://ecomodder.com/forum/showthre...uck-34674.html
aerohead (10-10-2018)
