Thread: Rad area mod
Old 10-09-2018, 08:25 AM   #5 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Without a source of fresh air, it will continually heat up under the hood until it overheats, even if you have fans. Ideally you'll have a clear path from grille to radiator to undercarriage, and close the grille opening until you have just a little more opening than is necessary in the worst case you see in your driving.
