Old 10-10-2018, 07:59 AM   #16 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by hat_man View Post
I'm not quite sure how I'm going to skin it. I was thinking about maybe a layer of chicken wire strategically snipped to follow the compound curves, then glass fabric and two part epoxy resin. Once the outer skin is done then maybe the same treatment on the inside for some extra strength.
chicken wire is flexible enough you should be able to squeeze it together, instead of cutting and creating sharp little pointed loose wire ends to jab you.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (10-17-2018)
