Old 10-17-2018, 04:54 PM   #3261 (permalink)
aerohead
solar
There is plenty of evidence out there man isn't the driving force behind climate change. The believers just chose to ignore it.
The biggest one is solar forcing.
Main reason being the only solar forcing related papers the belivers will even look at is from the mid 1990s and agrees with their narrative.
But that's going to all change in 2021. There is a satellite going up that will specifically study the interaction between the solar wind and the earths atmosphere, weather, jet stream, ect.
This will absolutely confirm the suns impact on weather at first and climate as the data piles up.
I will have a tombstone made.
"Man made climate change
197? - 2022"
The Parker Solar Probe is only there to figure out why the solar atmosphere is hotter than the Sun.It has nothing to do with anything else.
Solar irradiance of course is critical to Earth's climate,and the solar constant is what's at issue.And the Sun has been observed since 1611 when Galileo discovered sunspots,and observed it's rotation.
So far,no solar observatory has measured a variation in solar output of such magnitude that could account for global warming.
Venus is twice as far from the Sun as Mercury,but twice as hot!
Mercury,for all intents and purposes has zero atmosphere.
Venus has a nearly all-carbon-dioxide atmosphere,and it's why Venus remains 844-degrees F,day and night,with continuous winds of 200-mph.
It's the carbon dioxide!
And the reason Earth averaged 58-degrees F until recently,instead of Lunar temperatures is because of our atmosphere.
As we continue to increase Carbon dioxide,we must warm,just as with Venus.
Our models are good enough,since 1995,to predict warming,and Ockham's Razor dictates that we need not further investigate gross, causal couplings.
NeilBlanchard (10-18-2018)
