Old 10-23-2018, 10:23 PM   #21 (permalink)
redpoint5
90 day: 38.47 mpg (US)
If these batteries can charge so fast what's the upper temperature limit?
Because it's going to produce heat.
Not necessarily though, if the internal resistance is sufficiently low. Capacitors generate very little heat by accepting a static charge, and All Darc mentioned that this battery operates as a capacitor, at least partially so.
