Old 10-23-2018, 09:23 PM   #21 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 25.04 mpg (US)
If these batteries can charge so fast what's the upper temperature limit?
Because it's going to produce heat.
Not necessarily though, if the internal resistance is sufficiently low. Capacitors generate very little heat by accepting a static charge, and All Darc mentioned that this battery operates as a capacitor, at least partially so.
Old 10-23-2018, 09:24 PM   #22 (permalink)
That's a good question. The efficience it's over 99%, I believe, so the heat would not be very high.
The most polemic point, and I was leting it to the end, is that they siad it can convert some heat from room to electricity.
Old 10-23-2018, 11:20 PM   #23 (permalink)
I have blown up capacitors.
So the battery is partly endothermic?
Old 10-23-2018, 11:59 PM   #24 (permalink)
I don't know.
One report talked about some principle on quantum theory. But it was more about to explain lithium in both, cathode and anode.
Old 10-24-2018, 11:39 AM   #25 (permalink)
Thank you for taking this initiative.
I suspect the clip ends just before things get really bad. With the motorcycle going under the chase car and the driver slamming the brakes with the guy poised on top.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 10-24-2018, 12:16 PM   #26 (permalink)
Totally, and utterly, invincible.
Old 10-24-2018, 12:25 PM   #27 (permalink)
No more questions ??
I will collect the questions you guys made, add my own, and some introduction for interview, and send to Maria Helena Braga. And cross finger to her get time to respond soon.
If things went right, and based in her answers, let's see if she accept to respond a second round of questions you may get by reading what she says.
It could be nice if she answer the question in a video, like in a live, as it would be fast for make. Do Ecomodder have a video channel ? It would be ideal.
Old 10-24-2018, 12:54 PM   #28 (permalink)
You could simply record it, save to Youtube, and link here.
For a back and forth exchange, a Skype conference call could be setup.
Old 10-24-2018, 01:07 PM   #29 (permalink)
Why does ecomodder not have a youtube channel?
Old 10-24-2018, 01:11 PM   #30 (permalink)
It does. Darin and I are too lazy to make videos for the most part.
https://www.youtube.com/user/EcoModderDOTcom
