Petrol
For WAI I have removed the standard Intake shroud - removed original filter- replaced with cone CARGO filter .From measuring on my CRP123 Launch unit my intake averages between 45 and 66 degrees.
The Tyre pump is mounted next to the filter box and intake to this pump the temperature is basically the same as intake - although on the other side of engine .
I can get hotter air if I take a feed from the exhaust but I want to get the fuel vapor +
HHO and water vapor system installed and take it from there.
