Old 11-16-2018, 03:48 PM   #9 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
My Insight suffers from this as well. The engine even has exhaust heat recovery - there's a water jacket over the exhaust. When it's below freezing and I turn on cabin heat, I start losing coolant temperature, nevermind when it's 20 below zero. Cabin air recirculation helps but then my windows fog up. A 100% grille block helps, but isn't enough. Pre-warming the engine helps, but doesn't stop it from cooling back off after I'm driving.
And before you ask, my thermostat is fine, it's only when running heat.
Isaac Zackary (11-16-2018)
