Old 09-03-2008, 10:28 AM   #7 (permalink)
Daox
If you find yourself accelerating to a speed that is too high on the down side of a hill I would first try to crest the hill at a lower speed (using less energy to get up and saving gas). If this is not possible, I would then put the car in gear to reduce or hold at or under your max speed. The reason I would recommend this is because while you are coasting in gear, you are using no fuel.
Does that answer your questions? I didn't quite understand your last part about DWL.
