Originally Posted by mpg_numbers_guy
It's official! After months of searching I finally scored an Insight.
Congrats! A first gen insight was my second choice, right behind the accord.
Planning on replacing the wheel bearing and getting the engine valves adjusted
U
WOT M8? That engine has screw type valve adjusters, which are really easy to work with and learn valve adjustments from. I made a thread on another forum instructing how to adjust the valves on a K24, you can check it out to see what you are getting yourself into. A valve adjustment would likely cost you around $300, so you could easily save that if you can do it yourself.
https://www.driveaccord.net/forums/1...ment-pics.html
