Old 11-30-2018, 09:21 PM   #139 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
I joined the warm air intake club today. That is 4" dryer hose. It was quite a challenge to stuff that hose in there, not much room in the engine bay with the V6. The hose is sucking air from right by the pre-cat.
Someone with previous experience with warm air intakes should chime in, but I expected to see the intake temperature rise fairly quickly. It was 55F outside and I hit 100F coolant temperature before the intake temperature even moved. The highest temperature I saw was 57F over ambient, which is definitely higher than normal, but not by much. My usual scangauge setup does not include the intake temperature, but I have run it before and saw 40-50F over ambient when frequently coasting in neutral.
I only took it on a short drive, so I will have to report back later with the full results. The tube wasn't as close as it could be to the pre-cat, so I moved it a little closer, but I probably need a shroud to get the full effect of the exhaust heat.
ID:	25160   Click image for larger version
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
