Old 12-03-2018, 01:08 PM   #6 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by pedalcarpusher View Post
I've been tooling around with the idea of building a fiberglass fairing to replace the Coroplast one day.
It may improve the aerodynamics a bit, but you'll likely loose because of the weight issue.
You've got the worst aerodynamic issue sorted as-is.
Maybe a bit of tape here and there.
Covering the wheel wells might improve efficiency - see aerocivic.com for ideas on how to manage wheels prodding against (bungee spring-loaded) covers
The coroplast is cheap and easily replaceable as well.
