Old 12-08-2018, 05:34 AM   #13 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by serialk11r View Post
I still wish more companies would do the cushion on frame seat, I find all the adjustability in fancy new cars to be pretty silly. The most comfortable position is where you're leaned back a good amount, the knees are pointed slightly upward, and you can reach the pedals and wheel comfortably. The LaFerrari does this with moving pedal box, and I think the Ford GT has a normal bucket seat bolted straight in with moving pedal box (the rear of the seat is probably hooked into the roll cage I'm guessing so it's not dead weight).
I can't sit in a car with the seat tilted back, it hurts my lower back. I need to be mostly upright. A more flat seat bottom also helps.
Swapping the seats out from my Insight got me the adjustability I needed to prevent backaches when driving, at the cost of added weight.
