Old 12-09-2018, 10:19 AM   #115 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by hamsterpower View Post
Between the 6th and 8th generation Civics, Honda reversed the rotation of the engines. ...
He says his car is an '05 HX, which makes it 7th generation, which was before the rotation reversal.
Oh, and on the question of other possibilities for a trans mod... an obvious simple mod would be taller wheel/tire combos. You have the 4x100 bolt pattern and 14" wheels were probably stock on your car (depending on trim level, I think). So swap to a 15" wheel an taller tires, the effect is taller gearing. I am running 15" seven hole rims from a first gen MINI.
logix (01-03-2019)
