Old 12-11-2018, 03:09 PM   #4015 (permalink)
oil pan 4
Inverters are cheap if you buy large multi Kw level ones.
They can be had for under 15 cents per watt of capacity for residential solar installs.
Utility inverters that produce 480v power are even cheaper.
I remember not that long ago the inverter was the most expensivepart of the system by far with inverter costs at nearly $1 per watt
aerohead (12-12-2018)
