Old 12-16-2018, 10:42 AM   #4 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Heed what RedDevil said, it's good advice.
You should not need the additional deep cycle battery if you put on a trickle charger every night. If the stock battery fails, replace with an Odyssey AGM battery.
When it is time to replace tires, look for low rolling resistance tires. The Nokian Hakkapeliitta tires on my truck are stamped "Ultra Low Rolling Resistance" on the sidewalls.
Install a kill switch and use it freely. The goal is to eliminate engine idling by shutting it off.
The Following 3 Users Say Thank You to JRMichler For This Useful Post:
DeliveryGuy89 (12-16-2018), MetroMPG (12-17-2018), RedDevil (12-16-2018)
