I have had incredible luck with Gorilla Glue or it's opaque white counterpart, Sumo Glue. Good results require a fairly specific process, though. You will need something to punch many tiny holes in the surfaces of the Coro to be joined. I used a wallpaper scoring device. Then apply the glue to one surface, and use a spray bottle full of water to mist the other surface. Press together and hold with a clamp for an hour or so, overnight if you can stand it. I have several RC aircraft wings made this way. One of them survived a nose-in crash from around 200'. The wing separated on impact and was found several yards away. If done right, this method will work VERY well.
