Old 12-22-2018, 11:18 AM   #97 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Cowmeat, thanks for the links!! I actually just read through your Ron Burgundy thread yesterday and man, that was one gorgeous Insight! Too bad it just disappeared. How long did it take you to wire everything up?
An interesting idea. It may not even be necessary to store the variable, but just to have the arduino on a relay that interrupts the real signal coming from the battery for a moment. One *possible* flaw with this is that the car may not respond instantly to a change in battery state, e.g. you might have to wait a few seconds before it will start behaving as if SOC is 0. It might also put the car in forced charge. I'm not sure. Worth trying! You should also try the clutch switch and see just what it does in your car.
Won't interrupting the signal cause the IMA light to turn on? And since this would be a modification of the original clutch mod, doesn't the clutch mod prevent regen, but still allow assist (which is why the 0% SOC spoof would be necessary)?
Right now I'm at loss to figure out how to remove the lights from the rear of the Insight to measure the sockets...with the Civic I could just pull some carpeting back and voila, the lights and sockets were right there. On the Insight I can't see how to access them unless I literally remove the bumper and the entire light housing..
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
