Old 12-24-2018, 12:22 PM   #2924 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
How about the Tritan A2... a three wheeler with a 440cc rotary (!) engine:
More info:
https://www.allcarindex.com/auto-car...A2--Aerocar-2/
The unique design of the A2 has such low wind resistance that it requires only half as much horsepower as a motorcycle, and only a third as much as a car. The very low drag coefficient (Cd) of .150 translates into extreme aerodynamic stability for such a lightweight vehicle (weight is approx. 900 pounds, depending on drive train installed).
The vehicle’s Amick Arch can handle gusty crosswinds (while its vertical airfoil-shaped fixed sails convert side wind to forward thrust). Centers of gravity, side pressure, and lateral resistance are optimized to provide maximum vehicle safety.
Body is monocoque/fiberglass construction, with urethane nose and tail bumpers. Can be registered in most U.S. states as a motorcycle.
Other safety features: wedge-shaped front end that tends to deflect impacts; a highly visible profile in traffic; panoramic windshields; a collapsible steering column; exceptional aerodynamic stability; all-weather radial tires; quartz halogen headlights; and a manually operated emergency brake.
Engine & performance:
Position: Rear
Type: Rotary SP-440
Capacity: 440 cc
Power: 30hp @ 5500 rpm
Drive: RWD
Top speed: 153 km/h
0-100 km/h: 17 s
Dimensions:
Length: 4166 mm
Width: 1753 mm
Height: 1346 mm
Wheelbase: 2159 mm
Weight: 408 kg
For sale on FB
https://www.facebook.com/marketplace...9375731419146/
ID:	25293   Click image for larger version
The Following 3 Users Say Thank You to samwichse For This Useful Post:
aerohead (12-26-2018), Ecky (12-24-2018), NeilBlanchard (12-27-2018)
