14 thousand tons per second is nothing.
The glaciers retreated nearly a thousand miles in as little as a few hundred years at the end of the last ice age.
Man didn't cause that by lighting a few camp fires.
Bright Insight
The Bright Insight Youtube channel did three episodes that are the most reasonable explanation of Atlantis' fate; then followed it up with the cause of that
and the beginning of the Younger Dryas.
NASA recently discovered of a massive, 19-mile (31km) wide crater, found hidden underneath Greenland’s Hiawatha Glacier.
This furthers my argument that infrastructure should be hardened against heat, cold and high winds.
