Old 01-01-2019, 05:56 PM   #262 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Took the license bracket brick off the front of Ruby today. Since Florida only has a rear tag there's no need for it, and it ruined the look of the grille so off it came. Took about ten minutes to remove it. I had to drill out four rivets, unfortunately that meant there were four holes in the grille from when the frame was attached
It didn't turn out perfect (since I used aluminum tape over the four rivet holes as a temporary measure) but it looks a lot better than it did, and I'm sure there's a little aero gain there
I'll look for a permanent solution at some point, but this will do for now
On a side note it's been unseasonably warm even for Florida for the last week so I'm seeing my best numbers yet in the Volt, and over a 70 mile EV range. Hope the warm snap lasts all the way to spring (which is February here)
ID:	25345   Click image for larger version
ID:	25346   Click image for larger version
The Following 4 Users Say Thank You to cowmeat For This Useful Post:
19bonestock88 (01-02-2019), Bill the Engineer (01-05-2019), KFM (01-02-2019), ocnorb (01-01-2019)
