Originally Posted by Daschicken
The thing about carbureted engines is that sometimes you CAN'T drive off right away. Well behaved carbs will let you drive off right away, but sometimes carbs kill the engine just touching the throttle if it is cold and the choke isn't set right.
Well, anything won't work if it isn't set right. My VW Thing was a champ all winter.
