Old 01-02-2019, 07:50 AM   #428 (permalink)
RedDevil
90 day: 56.53 mpg (US)
Originally Posted by California98Civic View Post
I got the opportunity to finish blanking the holes on my 2007 BMW MINI seven hole rims. The mod creates a "flat" surface to improve aerodynamics. Preventing the airflow from flowing THROUGH the rim face should prevent much of the turbulence created by wheels. I don't use my brakes enough to worry about excessive heat and fade ... Here is the look:
What did you use to blank out the holes? Looks like foam board?
I was thinking about doing something like that, turning and rolling an aluminum sheet to make an inner cover for the rims in addition to a flat one on the outside. It needs to be shaped to miss the brakes, or I'd have to leave out a big hole for the hub. But I'd prefer it whole to have it locked down by the wheel.
I once covered the wheel covers on my winter set, but they tore and collected dust and stones on the inside.
