Old 01-02-2019, 11:07 PM   #5 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Tires showed up. Finally...
Will be mounting them up tomorrow at work.
17/42 Sprockets and a DID(?) chain on their way. Thermostat and DL650 parts come later.
Originally Posted by jkv357 View Post
If it has a full Yosh system on it, you are going to want to put a full factory system back on it. Typically aftermarket performance exhaust systems are going to have large diameter header pipes. You aren't going to want that for maximum efficiency.
I went and measured the pipes, and believe it or not, the yoshi system appears ever so slightly smaller. Something like 40.9mm outer diameter vs 41.1mm.
Some exhaust pictures:
Back of stock pipes
Side of stock pipes
Back of Yoshi
Side of Yoshi
Could also bump the heat range of the plugs up one if you plan to keep the revs way down.
I plan on bumping the operating temperature up with the new thermostat, as well as completely blocking off the oil cooler, I think the engine will be hot enough that the stock heat range is still a good choice.
I'd go with a lighter full synthetic 5W-30 cycle oil like Motul 300V (pretty sure you can get it in a cycle oil).
A little late to put different oil in it now! Next time I change the oil i'll probably put a 5w-30 or 10w-30 motorcycle oil in it, like Honda HP4. On the subject of oil, I brought out my 1"x5" oil heater pad and it looks like I may be able to stick it on.
A taller windscreen may help also.
Rear fender and grab bar should go...
I am not afraid to go into a full tuck, so a taller windscreen would likely not be helpful. The grab bar has already come in handy to pick up the rear of the bike and shift it around, and the rear fender stays.
ID:	25361   Click image for larger version
ID:	25362   Click image for larger version
ID:	25363   Click image for larger version
ID:	25364   Click image for larger version
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
