Originally Posted by hayden55
Its common Ford gears. Typically the lowest you will fine are 2.73, 3.08, 3.15, 3.31, 3.45, 3.55, 3.73, 4.10.
That is a fact, they are rare, but at one time for some cars or trucks they DID make them.
Here is the data I am working from:
Ring gear measures 8.8".
28 Spline axle shafts with a 1.29" diameter
31 Spline axle shafts with a 1.32" diameter
Ratios: 2.26, 2.47, 2.73, 3.08, 3.27, 3.31, 3.45, 3.55, 3.73, 4.10 & 4.56, 5.14
This is from here:
https://en.wikipedia.org/wiki/Ford_8.8_axle
Rich
