Old 01-08-2019, 01:58 PM   #35 (permalink)
racprops
Originally Posted by Angel And The Wolf View Post
I had a 54 Plymouth with an overdrive handle, but using that handle just let the car freewheel when coasting. No engine drag when off the accelerator. Don't know how it did that.
I know very well about the old Borg Warner 3 speed with Overdrive, and the free wheeling feature.
You can read up on them here:
https://www.fordification.com/tech/overdrive.htm
Before the new 6/8/and now 10 gear automatics I was planing on putting one between a auto and the rear end, as they are two transmissions in one, the three speed and the OD. I had one on a 1956 Studebaker that I rigged to shift into OD on any gear, so I had a 6 speed.
I would use 3rd and 2nd as a low and high range selector and use the OD with any forward gear, so I would have all kinds of gears.
It was complex and tricky but it could have worked.
But a all in one auto seems a much easier idea.
Rich
