Thread: Coal power
Old 01-10-2019, 04:11 PM   #133 (permalink)
freebeard
It's worse. There's also Pet Coke (petroleum coke)
https://grist.org/news/piles-of-tar-...ng-people-off/
This coke can either be fuel grade (high in sulfur and metals) or anode grade (low in sulfur and metals). The raw coke directly out of the coker is often referred to as green coke.[1] .... The calcined petroleum coke can be further processed in an anode baking oven to produce anode coke of the desired shape and physical properties. The anodes are mainly used in the aluminium and steel industry.
Petcoke is over 90% carbon and emits 5% to 10% more carbon dioxide (CO2) than coal on a per-unit-of-energy basis when it is burned. As petcoke has a higher energy content, petcoke emits between 30 and 80 percent more CO2 than coal per unit of weight.[4] The difference between coal and coke in CO2 production per unit of energy produced depends upon the moisture in the coal, which increases the CO2 per unit of energy – heat of combustion – and on the volatile hydrocarbons in coal and coke, which decrease the CO2 per unit of energy.
https://en.wikipedia.org/wiki/Petroleum_coke
aerohead (01-12-2019)
