Old 01-11-2019, 02:20 PM   #2932 (permalink)
The Toecutter
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
The 1963 Stanguellini Colibri is a thing of beauty. 112 mph on only 29 brake horsepower!
https://www.historicautopro.com/1963...ellini-colibri
Engine: mid-mounted Moto Guzzi.
Cylinders: 1, horizontal
Bore and stroke: 68×68 mm
Capacity: 248 cc
Max output: 29 bhp at 8400 rpm
Lubrication: full pressure with delivery and scavenge pumps
Cooling: air through air ducts
Valve gear: twin overhead camshaft driven by vertical shaft and spiral drive.
Fuel Feed: 1 Dell’Orto SS32 carburetor
Ignition: magneto
Clutch: multiple disc
Gearbox: 5 speeds; chain-driven final transmission
Chassis: tubular trellis
Front suspension: independent, lower and upper wishbones, coil springs with coaxial telescopic shock absorbers, anti-roll bar.
Rear suspension: independent, lower and upper wishbones, coil springs with coaxial telescopic shock absorbers
Brakes: disc on front wheels
Wheelbase: 2300 mm
Tracks: front 1100 mm; rear 1050 mm
Body: closed streamlined single-seater
Dry weight: 310 kg
Monza track October 1963,the Colibri driven by Pietro Campanella and Angelo Poggio
set 6 world speed records,the Stanguellini streamliner reach speeds over 180kph.
The Following User Says Thank You to The Toecutter For This Useful Post:
aerohead (01-23-2019)
