Old 01-13-2019, 02:26 PM   #3297 (permalink)
02BMW02
Many Thanks thingstodo,
I so hope this controller works for me, Ive had a run of back luck with controllers, have gone through two can bus controllers and Pauls drop in leaf board controller nothing worked, Paul has told me that there must a fault on the leaf main circuit board.
Ironically the board that I'm building was the first board I bought from Paul.
What version board to you have ? I have Ver 0.4
What setup are you running any pictures ?
I know you build your system a while ago.
I don't understand how to connect J43 & J44 "high voltage DC monitoring", do I need to wire resistors in series here ? eventually I will be using a Leaf pack 360V
